1 страниц (8 вхождений)
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - Сообщения
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127,5 КиБ) скачан 1131 раз(а).
Thank you
Thank you
WroteSome direction would be appreciated.
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150,39 КиБ) скачан 1149 раз(а).
WroteSome direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix
Don't miss the Truth Table Companion in Samples.
WroteAaah now I get what you meant.
This should solve your problem.
Deleted previous post.
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
WroteIs this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19,1 КиБ) скачан 1138 раз(а).
