plotting circle does not work
plotting circle does not work - Help - Сообщения
#1 Опубликовано: 13.03.2022 10:52:33
Blackbambi
Blackbambi
I am trying to plot mohr's circle by following tutorial. I have succeeded to draw circle on the tutorial but not mine.
Could you check my plot?
Thank you.MSS_Failure criterion.sm (8,47 КиБ) скачан 1241 раз(а).
#2 Опубликовано: 13.03.2022 11:47:06
Fridel Selitsky
Fridel Selitsky
One way to build a graph is to lower the order of large numbers
Primer.sm (8,51 КиБ) скачан 1173 раз(а).
#3 Опубликовано: 13.03.2022 12:32:01
You can make a function to draw circles, for multiple usage on same sheet.
With respect to Ber7, dividing it to MPa will lower the numbers too.
MSS.sm (7,3 КиБ) скачан 1211 раз(а).
#4 Опубликовано: 13.03.2022 22:37:25
Blackbambi
Blackbambi
Thank you all. I appreciate your help
#5 Опубликовано: 14.03.2022 13:06:17
Here is a version with pre-defined geometric object in the XY plot plugin. See Handbuch section 8.3.4.
MSS_Kr.sm (13,86 КиБ) скачан 1210 раз(а).
#6 Опубликовано: 14.03.2022 14:11:02
Circle de Mohr.sm (47,02 КиБ) скачан 1211 раз(а).
#7 Опубликовано: 15.03.2022 04:28:27
Blackbambi
Blackbambi
Thank you for sharing your work
#8 Опубликовано: 15.03.2022 09:42:51
There are many ways to plot circles wrt applications.
My most used brew ... Cheers, Jean.
Page4 Circles_Ellipses.sm (9,36 КиБ) скачан 1352 раз(а).
#9 Опубликовано: 15.03.2022 13:22:17
It is much easier to draw circles with X-Y Plot plugin.
circle_xy.sm (5,23 КиБ) скачан 1260 раз(а).
#10 Опубликовано: 20.03.2022 15:38:42
My most used brew
I prefer incremental discretizer.
Circle [QUICK,oblate_prolate].sm (14,23 КиБ) скачан 996 раз(а).
