[Image Region] Not woring on Windows 10 Laptop
[Image Region] Not woring on Windows 10 Laptop - Not woring on Windows 10 Laptop - Сообщения
#1 Опубликовано: 28.04.2017 16:08:04
shiju
shiju
1 сообщений из 7 понравились пользователям.
Smath is not properly working on my new windows 10 laptop.
While loading the Smath program, the loading image suddenly goes smaller and then open the program.
But the side panel is not visible, and the work space height is loaded in smaller than the screen height.
When clicking the restore button near the close button at top corner, the side panel appears back.
The screen response to the mouse and the keys are slow.
Defining a variable is looking like not responding the program.
Can anybody help me....
Shiju
#2 Опубликовано: 28.04.2017 16:38:26
please check if you have the image region plugin installed and in this case remove it
#3 Опубликовано: 29.04.2017 05:26:40
shiju
shiju
Thanks Carpi, It works now.
Bye the bye, why is it so?
Shiju
#4 Опубликовано: 29.04.2017 06:13:50
Good
it's currently under investigation, but since I'm not able to reproduce on my Win10 it's a little bit tricky to find the cause...
#5 Опубликовано: 31.10.2017 01:29:05
Humberto Mendoza
Humberto Mendoza
Shiju
Hi Shiju!
How did you fix it? I have the same problem on my laptop which it's running Windows 10. I don't know if it has to do with any display setting or with the Windows version. I was getting started with Smath two months ago but I had to stop the learning process a few days after starting. Now, I'm beginning again and I face the same problem.
I would really appreciate any help on this topic.
P.S. Excuse me for my English, it is not very good
#6 Опубликовано: 31.10.2017 01:37:00
shiju
shiju
Hi
I removed the image region plugin. Then Smath is working fine now. Try this.
Shiju
#7 Опубликовано: 03.11.2017 13:28:54
Humberto Mendoza
Humberto Mendoza
Hi Shiju!
Thanks!! I removed the image region plugin and it's working now.
