Pre-Install Plugin check?
Pre-Install Plugin check? - Сообщения
#1 Опубликовано: 07.09.2018 19:32:55
dio pants
dio pants
16 сообщений из 180 понравились пользователям.
Can we have a check of plugins BEFORE we initiate installation?
It would be nice to know what is not compatible before we install so we can abort if our favorites are not supported.
I usually find out AFTER the install on the first run when it tells me the that some of my plugins are NOT compatible.
Dennis
#2 Опубликовано: 07.09.2018 20:11:45
This issue only about beta-versions. I suggest you to disable updates to beta-version and use stable ones only.
I plan to handle all plug-ins in about a week. New stable version will be released afterwards.
#3 Опубликовано: 07.09.2018 20:45:37
dio pants
dio pants
Andrey-
Yes, I believe that is correct that it installs without the check for Beta versions.
Looking forward to the next release.
Dennis
