SpiceSharp
SpiceSharp - Spice# electronic circuit simulator - Сообщения
#1 Опубликовано: 22.11.2024 07:14:57
SpiceSharp (Spice#) - electronic circuit simulator
SMath Studio compatibility History page Sources
Based on SpiceSharpParser (.NET library that allows to parse SPICE netlists and to simulate them using SpiceSharp library).
This plugin requires .Net Framework 4.7.2 to be installed for it to work.
I managed to run the first test example on my PC. The plugin is not available on the server yet.
Links:
1. SpiceSharpParser
2. SpiceSharp Home Page
Отредактировано 12.09.2025 17:04:15
Alvaro 23.11.2024 12:03:00
#2 Опубликовано: 22.11.2024 07:30:22
For experts only.
spice#.sm (5,15 КиБ) скачан 1962 раз(а).
Plugins folder: C:\Users\User\AppData\Roaming\SMath\extensions\plugins
SpiceSharp-0.1.9092.9246.zip (10,94 МиБ) скачан 595 раз(а).
francesco rapuano 22.11.2024 19:42:00, Alvaro 22.11.2024 12:54:00
#3 Опубликовано: 25.11.2024 12:45:27
Hi. A preview for exploring this powerful plugin.
spice# and MNA.sm (577,69 КиБ) скачан 1972 раз(а).
spice# and MNA.pdf (1,5 МиБ) скачан 1766 раз(а).
#4 Опубликовано: 25.11.2024 13:05:39
I haven't even tried these features myself yet. Support for all types of analysis hasn't been tested. There's still a lot of work to do. Maybe I'll do a direct insertion of values ​​into the circuit description. I wanted to try making a circuit with an amplitude detector. The authors have recently added the ability to specify an amplitude-modulated signal. They have a shell (GUI) in which you can also test circuits.
#5 Опубликовано: 25.11.2024 13:23:12
Hi Viacheslav. As far as I could see, the plugin you created works very well, it just has some very minor details, like not recognizing either "u" or "μ" for micro. By the way, handling that is a configurable option in ltspice. So you shouldn't be the first one to have problems with that.
As for the analyses that spice# has, it's just a matter of discovering them, since the documentation they have is very little, and for example, I don't know what convention they followed to enumerate the nodes of the controlled sources. I took the one they use in the Qucs simulator, but there is no standard for that.
I saw the GUI for windows that you mention on github, except that they didn't compile it... or at least I didn't find it, only the source code.
#6 Опубликовано: 25.11.2024 15:21:40
Similar project. I assembled it, but I haven't tried it in work.
NextGenSpice_20241125.zip (321,63 КиБ) скачан 615 раз(а).
Links:
1. NextGenSpice/Program.cs
2. NextGenSpice/plot.ps1
Alvaro 25.11.2024 23:42:00
#7 Опубликовано: 01.12.2024 10:51:11
New version, more compatible with spice# sintaxis.
spice# and MNA v2.sm (636,64 КиБ) скачан 1897 раз(а).
spice# and MNA v2.pdf (1,63 МиБ) скачан 1654 раз(а).
#8 Опубликовано: 10.12.2024 01:23:50
A task for implementation in the future:
Практический расчет параметров индуктивности
https://forum.cxem.net/index.php?/topic/270218-практический-расчет-параметров-индуктивности/
#9 Опубликовано: 11.01.2025 16:41:49
SMath Studio compatibility History page Changes
Plugin updated.
Changes:
- Plugin adopted to a new SMath Studio Core infrastructure;
- Folders removed from the output artefacts.
Отредактировано 12.09.2025 17:04:34
Oscar Campo 11.01.2025 17:46:00, Andrey Ivashov 11.01.2025 17:00:00, Davide Carpi 11.01.2025 19:57:00, Alvaro 12.01.2025 15:48:00
#10 Опубликовано: 10.09.2025 20:57:16
SMath Studio compatibility History page Changes AI Assistant
Plugin updated. [BETA]
Changes:
- expanded capabilities of spice#() function.
spice#-tran-example01.sm (10,7 КиБ) скачан 1217 раз(а).
Отредактировано 12.09.2025 17:03:55
Alvaro 11.09.2025 03:57:58
#11 Опубликовано: 11.09.2025 04:06:20
Hi. Using MNA method
spice# and MNA v2.sm (653,28 КиБ) скачан 1226 раз(а).
#12 Опубликовано: 11.09.2025 15:34:13
spice#-tran-example02.sm (11,84 КиБ) скачан 1214 раз(а).
#13 Опубликовано: 11.09.2025 20:24:35
Plugin updated. [BETA] 🤪
Changes:
- Custom Icon/Glyph Rendering
- Automatic Export from .SAVE Statement.
- Automatic Interpolation Function Generation.
spice#-tran-example03.sm (11,78 КиБ) скачан 1235 раз(а).
Отредактировано 12.09.2025 17:05:04
Oscar Campo 12.09.2025 10:04:14
#14 Опубликовано: 12.09.2025 10:09:29
Changes:
- Refined Glyph Rendering;
- Added "spice#'Options'Interpolator" Operand.
Отредактировано 12.09.2025 17:05:27
#15 Опубликовано: 12.09.2025 11:10:39
It works
Alvaro 12.09.2025 18:01:36
#16 Опубликовано: 12.09.2025 18:09:05
Hi Viacheslav. Great work, congratulations. Some questions:
I was able to introduce an ampop, which is a fairly theoretical model without many physical parameters. How did you introduce the diode model?
Is it possible to import ltspice models more or less automatically?
Another question: how could V1, V2, and V3 be graphed in your 3DPlot plugin? The CreateSpace function is new, isn't it? Do you have examples of how to use it? Generally, these graphs can't be created in simulators, and the data must be exported to MATLAB or other similar software.
#17 Опубликовано: 12.09.2025 19:20:54
I can tell you how to proceed, i.e. the algorithm for setting the problem.
If you want to simulate the scheme, then you need an example. Nowadays, in the programming world, it is common to accompany source texts with tests. These tests, as a rule, cover many typical tasks.
You need to find these texts, see the link below. Then introduce Gemini to the matter so that he can help create an adequate syntax. I simply throw the test sources into the chat as an example and say what I need.
Show me an example, if I do this, then yes, it can be done almost automatically and I will tell you how.
Not at the moment, but I can make it so that it will be possible. I don't have enough time to finish this plugin, as it is a bit more complicated than X-Y Plot.
Yes, CreateSpace() is a new function, I asked Gemini to make it, but I haven't used it yet. The plugin does not support the data format returned by this function.
Links:
1. SpiceSharpParser.IntegrationTests
Alvaro 12.09.2025 19:45:30
#18 Опубликовано: 12.09.2025 19:56:21
Hi Viacheslav. Thanks, the link you provide shows how to simulate components, for example, a diode:
One more question: An option to have outputs with units? I think it would just be a matter of identifying time, volts, and amperes. It would be very practical to be able to use milli, micro, and nano prefixes.
Отредактировано 12.09.2025 20:03:32
#19 Опубликовано: 12.09.2025 20:27:17
Good advice. We need to think bigger. I want to add elements from the sheet to the schema code. For now, this is done in a limited way, because there is not enough time to think of a convenient solution, but in general it will be possible to both set variables with units separately and get a response with units.
There is probably some support for this in the library code. I'll take a look.
