Problem with Optimization
Problem with Optimization - Сообщения
#1 Опубликовано: 16.01.2012 07:28:25
Edward Ulle
Edward Ulle
The following file will crash if Optimization is set to Symbolic with SMath 0.9. Just something for Andrey to play with in his spare time. :d
https://smath.com/wiki/GetFile.aspx?File=forum_attach%2fTheWizEd%2f4100422_New_Crane_Beam.zip
Ed
#2 Опубликовано: 17.01.2012 04:27:51
Thank you! Will fix it soon.
#3 Опубликовано: 17.01.2012 04:52:40
Edward Ulle
Edward Ulle
Andrey,
Could you explain the purpose of the Symbolic and Numeric Optimization and when either is appropriate. If I turn on Numeric Optimization and hoover over an equation I see fractions with numbers with 10^15 or higher. I believe its to come up with a denominator which is the largest integer value. Why not just use the floating point value of the equation?
Ed
#4 Опубликовано: 23.01.2012 19:00:09
Fixed.
Radovan Omorjan 23.01.2012 20:36:00
