RC: SMath Studio 0.98.5910 (07 March 2016)
RC: SMath Studio 0.98.5910 (07 March 2016) - Сообщения
#1 Опубликовано: 07.03.2016 20:01:08
SMath Studio 0.98.5910 available
Latest changes (against SMath Studio 0.98.5908)
  • Language translations updated (for new UI elements, functions, buttons, units);
  • Numeric library improved to prevent StackOverflow exceptions in future;
  • RichScrollbars improved (using double buffering to prevent flickering, support system with disabled Visual Styles, horizontal ScrollBar focus, context menus, etc);
  • Minor corrections to prepare application for next stable release;
  • Refactoring.
Download
ioan92 08.03.2016 04:07:00, Davide Carpi 07.03.2016 20:42:00, Василий Николаевич Храмушин 07.03.2016 21:55:00
#2 Опубликовано: 07.03.2016 20:05:21
Please note: this is release candidate. No more significant improvement will be done this sprint. The main goal now is to publish first 0.98 stable release and to start new sprint.
Thank you for testing!
Davide Carpi 07.03.2016 20:42:00, ioan92 08.03.2016 04:07:00, Martin Kraska 08.03.2016 07:30:00
#3 Опубликовано: 08.03.2016 07:59:30
1 332 сообщений из 2 241 понравились пользователям.
The scrollbar is now visible and functional, however, with windows classic theme, it is plain black on plain white instead of grey as in previous versions of SMath and in other win applications.
#4 Опубликовано: 08.03.2016 09:13:47
It is by design. I think I will do some cosmetic changes to scrollbars soon, but they will not look as default on your system anymore. Theme you use on your PC doesn't allow me to reuse system scrollbars design at all, so, unfortunately, I have to fully draw them by myself.
#5 Опубликовано: 08.03.2016 09:36:54
Limited backward-compatibility seems to be the price for the enriched scroll bars. I don't expect you to do extra work just for that. Maybe, one day, the brand new windows look will be 1bit color, than we are compatible again ;-)
#6 Опубликовано: 11.03.2016 18:04:50
Igor Skarine
Igor Skarine
14 сообщений из 97 понравились пользователям.
Hi Andrey,
I noticed, that my favourite Mathcad EFI plugin is broken now.
It looks like only Kronkr.dll is reachable.
All other EFI functions are unavailable.
#7 Опубликовано: 11.03.2016 19:31:25
Hello.
I've rebuild Mathcad EFI plug-in. Please try to update it using Extensions Manager and check if issue is fixed.
Also please ensure you use it on 32-bit system.
If any additional questions appear please use the following topic: http://en.smath.info/forum/yaf_postst755_Mathcad-EFI.aspx
Thank you!
Davide Carpi 11.03.2016 22:09:00
#8 Опубликовано: 11.03.2016 19:33:07
I've made some improvements, so scrollbars now looks much better on systems with disabled visual styles. New SMath Studio nightly build coming soon.
