How to output data to a csv file
How to output data to a csv file - Syntax for output - Сообщения
#1 Опубликовано: 23.02.2019 19:30:21
RegCurry
RegCurry
0 сообщений из 57 понравились пользователям.
I am trying to write data to a csv file. On the forum, I have seen examples of output_CSV and “outputData (subscript CSV)”. I cannot get either to work. My data is a two column matrix.
If this function works in SMath, any help on the correct syntax would be appreciated. Perhaps it requires a plugin. If so where can I get the plugin?
Also,where will the csv file be located?
Thanks much.
Reg
#2 Опубликовано: 23.02.2019 20:38:47
Arie
Arie
You can use the data exchange plugin. To install go to Tools->Plugins... -> Click (Local Storage) and select Online Gallery -> Look for "Data Exchange" -> Double Click to install.
A simple example of exporting to CSV is shown below. Note: you will need to save the .sm before exportData function will work.
csvExport.sm (2,81 КиБ) скачан 1048 раз(а).
#3 Опубликовано: 23.02.2019 21:15:47
RegCurry
RegCurry
Thanks again for all your help.
It still does not seem to work for me. I installed the Data Exchange Plugin and used the following syntax.
I keep my .sm files files in the following directory. C:\Users\Reg\Reg Documents\MATH_SMATH
The file was not located here.
It is also not located here: C:\Users\Reg\AppData\Local\Programs\SMath Studio
#4 Опубликовано: 23.02.2019 21:39:04
RegCurry
RegCurry
Alyles,
Thanks again. I discovered my issue. The = is a symbolic evaluation.
Thanks,
Reg
#5 Опубликовано: 24.02.2019 10:02:43
Not quite so ... =1 is logical answer "yes saved"
1. select your matrix in Smsth
2. Copy
3. Paste in Excel LibreOffice
I tried but it pastes as line instead of column.
Never ever used Excel since 2000 !
