1 страниц (5 вхождений)
LM Algorithm !! - Сообщения
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Shina
Shina
WroteFor this particular example, Carlos algorithm spits out in < hart beat !
Shina
Could you be more specific please. What example are you talking about?
Davide Carpi 03.07.2019 10:32:00
Please, share your application.
LM covers a good % of all fits in Mathcad.
Cases LM fails, Conjugate Gradient is the sole rescue.
Many model functions can only be fitted by hand.
Shina
You are right About LM, however not so simple.
al_nleqsolve, LM, ConjugateGradient that produce in Smath, all dependent
upon initials and reflexivity of the model +++ the approach technique.
Data reduction is a great approach technique [Kirby, Thermocouples ...]
In Mathcad LM as well as CG, a technique that works well to initialize
wrt many models is to pass manually initials through 2 points.
That was not explored with Carlos LM.
That technique through 2 points did work well in some Smath fit,
but failed in other fits. Maybe you are working hard on that stuff ?
Attached for the interest of this visit.
Genfit Chemist.sm (34,16 КиБ) скачан 1231 раз(а).
Genfit Minimize Rational KHL.sm (45,36 КиБ) скачан 1211 раз(а).
Genfit Pharmacokinetics.sm (41,84 КиБ) скачан 1245 раз(а).
Shina
