Reset/Remove Variable
Reset/Remove Variable - Variable delete - Сообщения
#1 Опубликовано: 16.10.2012 13:24:00
Topsi
Topsi
Dear members,
in often times I need the variable x . Then in next time I make
in Example a differential of Function, and x is rember of value or defition.
In mathCad I remove a variable with x:=x.
What can I do in SMath ?
So many thanks for help.
Topsi
#2 Опубликовано: 16.10.2012 13:39:01
Dear members,
Topsi
Hi Topsi,
AFAIK the only way it's to use a 2nd empty variable.
f.e.
[LIVE width=170 height=157]http://smath.info/live/?file=4019[/LIVE]
regards,
w3b5urf3r
#3 Опубликовано: 16.10.2012 16:02:58
Topsi
Topsi
Hello w3burf3r,
thanks for your help, but I can't type the symbol # in place holder.
A free new variable, that will be good. But in the teaching I will
have always the x - variable.
Have you a little helb for this new question.
Thanks for help
Topsi
#4 Опубликовано: 16.10.2012 18:11:18
Hi
I know, it's not a wonderful solution... I've already attempted to create a Clear() function inside a plugin - nothing to do
You can post a Feature request in the forum, IMHO would be an useful feature
As for the # character, you must write at least one letter and then you can write the # before the first character (I don't know if this is a bug or a feature).
regards,
w3b5urf3r
#5 Опубликовано: 17.10.2012 10:02:17
Oscar Campo
Oscar Campo
An easy way to remove a variable is use another variable but undefined:
ClearVar
So, you must the "clean" variable undefined.
Oscar
#6 Опубликовано: 17.10.2012 12:41:31
ClearVar
Sorry, does not work here. Clean removal would make X appear as result in the mapUnknown function from the NonLinearSolvers plugin.(see here).
Best regards, Martin Kraska
#7 Опубликовано: 17.10.2012 15:46:32
Topsi
Topsi
All helpers,
many thanks,
sorry, but my problem ist not lost. That is very trouble of SMath that I can't
remove a variable. See what I meen:
x:=3
x=3
x:=clean
x=
f(x):=x³
d
- f(x)=3 clean²
dx
that is very bad.
I think in the next version it will be.
So if anywhere help me than I give thanks bevor.
Topsi
#8 Опубликовано: 19.10.2012 08:23:04
Oscar Campo
Oscar Campo
I see...
So I join the request for a clear() function: http://en.smath.info/forum/yaf_postst1576_clear---function.aspx
