roots() bug with a simple linear system of equations
roots() bug with a simple linear system of equations - roots() returns "not real roots" - Сообщения
#1 Опубликовано: 23.06.2013 21:15:46
Diego Jarrín
Diego Jarrín
7 сообщений из 14 понравились пользователям.
Trying to solve a simple linear system of equations (2 equations) using the roots() function gave me the error message "No real roots", but changing the order of the elements of one of the equations, solved it.
roots() rare behavior
I know this is not so important, but it was interesting to see how SMath`s functions behaves.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
Davide Carpi 24.06.2013 05:52:00, ioan92 24.06.2013 04:24:00
#2 Опубликовано: 24.06.2013 01:28:09
Confirmed,
It seems some bug is here.
FindRoot() from Nonlinear Solvers plugin will work well here
[MATH=eng]FindRoot(mat(A+B-108,2*A-3*B-156,2,1),mat(A≡0,B≡0,2,1))=mat(96,12,2,1)[/MATH]
#3 Опубликовано: 25.06.2013 04:06:19
Symbolic optimization fails to recognize the difference of the equivalent expresions to zero in one step. If the result is taken and again symbolically optimized, then zero is identified. Perhaps an internal workaround for such problems could be to repeatedly apply symbolic optimization until there are no more changes.
roots.sm (17,08 КиБ) скачан 1280 раз(а).
Radovan Omorjan 25.06.2013 07:28:00, Davide Carpi 25.06.2013 08:07:00, ioan92 29.06.2013 07:44:00
