Keyboard Shortcut for CR
Keyboard Shortcut for CR - Сообщения
#1 Опубликовано: 01.03.2019 07:51:45
calculate
calculate
isn't there any keyboard shortcut for "carriage return"
Michael
#2 Опубликовано: 01.03.2019 09:40:54
Hold the control key and press return (enter) OR hold the shift key and press return (enter)
CTRL+ENTER or SHIFT+ENTER
#3 Опубликовано: 01.03.2019 10:15:10
1. Typing text in Forum => Enter
2. Typing text in Smath [Writer Region & native Text] => Shift+Enter
Davide Carpi 01.03.2019 10:41:00
#4 Опубликовано: 06.03.2019 12:24:49
calculate
calculate
Sorry,
but Ctrl+Enter seams to be a page break
and Shift+Enter is a line feed.
I am searching for a command to move the red cross
back to the start of line (carriage return, but not
in a text region.
In Mathcad I can do this by simply pressing Enter.
And another question: How to remove a page break (Ctrl+Enter)
#5 Опубликовано: 15.12.2022 18:59:53
⚜ Kenny Lemens, P.E. ᵂᴵ
Greetings!
   I am unaware of any native support that allows you the ability for a carriage return (CR) and a line feed (LF). By virtue of this post, I did develop some code to perform such an action. The bad news is that I did not deploy this code as a plugin, but if you are a developer: you can copy/paste this code into your project:
- https://en.smath.com/forum/yaf_postsm79990_SMath-Keyboard-Shortcuts.aspx#post79990
   As to your second question: use your mouse & click-drag to highlight/select the page-break object; then keypress [delete] to remove.
May this be of Good Help, and may you be in Good Health;
- Kenny Lemens, P.E. ᵂᴵ
sergio 16.12.2022 07:18:00
