Help with plotting a function
Help with plotting a function - Help with plotting - Сообщения
#1 Опубликовано: 07.08.2012 12:31:47
Ward
Ward
I'm new with smath and need some help with plotting. I believe my issue is with the equation I set up to plot a cone. Take a look.
Thanks Ward
Cone_Notes.sm (7,43 КиБ) скачан 1401 раз(а).
#2 Опубликовано: 07.08.2012 13:23:54
Ward
Ward
I found part of the problem, my arrays were messed up.
#3 Опубликовано: 07.08.2012 14:29:21
Hi
if you use functions, you need to set the formula in the form z=f(x,y); in the attachments there is an example.
here ( SMath Studio Forum » SMath Studio » Samples » CreateMesh() ) there is a plugin for 3D meshes (I don't know if works with latest version of SMath)
P.S. the /in it's only to ease the reference with the axes
P.P.S. an implementetion of plots with gnuplot libraries it's possible? probably would save a considerable amount of time at andrey for the development of the graphics
regards,
w3b5urf3r
cone_function.sm (5,13 КиБ) скачан 1387 раз(а).
#4 Опубликовано: 08.08.2012 08:26:01
Ward
Ward
Thanks for the help.
