Coolprop wraper
Coolprop wraper - After update to 0.97.5737 - Сообщения
#1 Опубликовано: 20.09.2015 17:59:03
Arnel Džinić
Arnel Džinić
After the update, plugin coolprop Wraper crashes.
At an earlier version I manually installed coolprop 5.1.1 / 2 and everything worked.
I tried to install an older version and it worked again two days now I have the same problem
The loading
Of course I tried to delete both and install again only one, but I failed
#2 Опубликовано: 21.09.2015 04:28:57
1 436 сообщений из 2 916 понравились пользователям.
"CooProp Wrapper" updated (made it compatible with the latest SS)
Looking at the sources of "coolprop_wrapper" seems you need only to recompile it
coolprop_wrapper is the official plugin, made by Mike Kaganski, "CooProp Wrapper" in the gallery is the clone of an early beta made by him and published by me.
coolprop_wrapper contains more functions and coolprop's libraries always updated
documentation and link to sources and binaries: http://www.coolprop.org/coolprop/wrappers/SMath/index.html#smath
Andrey Ivashov 21.09.2015 16:29:00
#3 Опубликовано: 22.09.2015 14:59:02
Ryan Freund
Ryan Freund
I don't see this plug-in in my list of plugins, where is this plugin located? Just curious.
thanks!
#4 Опубликовано: 22.09.2015 16:42:59
2 318 сообщений из 3 973 понравились пользователям.
Did you try to turn on beta-versions of plug-ins?
Davide Carpi 23.09.2015 05:31:00
#5 Опубликовано: 26.09.2015 21:13:23
Ryan Freund
Ryan Freund
That worked, thank you. I really thought I had unchecked that...
