Basic input bug?
Basic input bug? - Parameter not defined - Сообщения
#1 Опубликовано: 11.10.2020 13:30:26
Jan Claeys
Jan Claeys
2 сообщений из 25 понравились пользователям.
Dear all,
I use SMath for quite some time now, however I have a very basic question about an input issue that annoys me from time to time.
This is probably the most basic question ever asked on this forum ;-)
When I make a new calculation sheet with the following input, I always get the error "parameter a2 not defined":
a.1:=2m (subscripted variables are used here)
a.2:=3m
a.1+a.2=error
I get this error every time in this specific case, the input happens fast as I'm used to the input procedure.
The TAB-key has been used for confirmation, but for the unit input (m) as for the variable input (a.1 & a.2).
When I save the above file containing the error and reopen it, a.2 is depicted as a2 so without the subscript.
Which mechanism could be at the source of the above behaviour?
Thanks in advance for any feedback!
Kind regards from a true SMath-fan,
Jan Claeys (Belgium)
Andrey Ivashov 12.10.2020 03:57:00
#2 Опубликовано: 11.10.2020 16:06:51
I experienced the same issue myself several times (both in desktop and android app versions), although I've not yet found a clear way to reproduce it.
#3 Опубликовано: 11.10.2020 16:41:09
Jan Claeys
Jan Claeys
Good evening Davide,
Thank you for your swift reaction!
Hopefully, the programming team can pinpoint the exact mechanism behind so that user safisfaction can be increased. If I could, I would resolve the issue myself but my programming skills are insufficient I'm afraid...
SMath is really a beautiful tool and it's popularity will undoubtly further increase.
Kind regards,
Jan
#4 Опубликовано: 11.10.2020 17:37:01
File missing ... since which Smath version ?
Subscript not recognized may have to do with the keyboard style.
#5 Опубликовано: 11.10.2020 18:06:22
Jan Claeys
Jan Claeys
Hello Jean,
I didn't attach a file since the issue is so straight forward. I could attach a file Tomorrow?
Since I can perform the input as I want, the keyboard used doesn't seem to be the problem here? The problem has to do with the way parameters are stored and recalled in the program itself? Maybe a compatibility issue with certain extensions?
This problem really grasped my attention in the 3 most recent versions, but is probably much longer present.
Kind regards,
Jan
#6 Опубликовано: 11.10.2020 19:48:08
File not needed because NO bug SS 6179
#7 Опубликовано: 12.10.2020 03:52:56
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
I use the german settings, which means comma as decimal symbol and semicolon as argument separator.
Sometimes I opened a file and was wondering about the unexpected results in the sheet. Then I found that the last entered decimal symbol, somewhere at a definition, was lost. Maybe that's the same issue.
But I didn't find a regularity.
#8 Опубликовано: 12.10.2020 04:00:54
Hello [USERLINK]janclaeys[/USERLINK].
Thank you for the report. I will try to analyze a code to see what could cause this issue. First impression is that it is something related to multi-threading.
Thanks all for details!
janclaeys 12.10.2020 15:22:00
#9 Опубликовано: 12.10.2020 07:30:52
NDTM Amarasekera
NDTM Amarasekera
a.2:=3m
a.1 a.2=error
No errors found.
#10 Опубликовано: 12.10.2020 08:01:53
Hello Jean,
Confirmed no bug. Get a QWERTY keyboard, set English US.
#11 Опубликовано: 12.10.2020 08:09:18
Copy the blue from page 3 ... paste page 14 [gray].
#12 Опубликовано: 12.10.2020 15:31:13
Jan Claeys
Jan Claeys
Dear all,
Thank you for the feedback!
@Andrey: thank you! I hope you can trace the concerned background process successfully. FYI: I use the most recent Windows incarnation (Windows 10 Pro; build 19041.508)
@Jean: it's a bug without any doubt (although not always repeatable), please see the screenshot below
Kind regards,
Jan
#13 Опубликовано: 12.10.2020 20:26:13
Collab NDTMA reported no bug latest SS.
I reported no bug SS 6179.
If a bug had appeared past SS 6179, it would have been reported.
It's your system/installation, end of it.
Go to the store, purchase:
1. QWERTY keyboard [English US]
2. a wired mouse, install
Wireless mouse is source of problem(sssssss) !
Your snippet can't be reproduced because there is no bug.
#14 Опубликовано: 12.10.2020 23:37:05
Hi. I can't reproduce the bug, but it could be interesting to know if, in the case you have the error, if you can see the tooltip about the variable value, as in the image. Isolated or when you write it into an expression. Obviously, autocalculation must to be on.
