Plot SMath 0.91 vs. SMath 0.92
Plot SMath 0.91 vs. SMath 0.92 - Сообщения
#1 Опубликовано: 06.03.2012 10:18:30
Oscar Campo
Oscar Campo
Hi Andrey,
I test the new version (0.93) and found the same problem that version 0.92. This is the result from same file.
Plotting in 0.91:
Plotting in 0.93:
Oscar
#2 Опубликовано: 06.03.2012 10:31:34
Hello Oscar,
Here is the same file I reported it was wrong in v0.92 (the same post when you reported your problem).
It seems to me quite right in v0.93. It must have been something else regarding your problem. Can not see what's wrong at the moment.
radovan
#3 Опубликовано: 06.03.2012 12:06:16
2 313 сообщений из 3 892 понравились пользователям.
This was fixed in 0.93 (the reason was a bug regarding constants).
#4 Опубликовано: 06.03.2012 16:41:02
Oscar Campo
Oscar Campo
Sorry, but in my post I show that problem persist in 0.93. It is not fixed.
Oscar
#5 Опубликовано: 06.03.2012 17:53:15
1 434 сообщений из 2 909 понравились пользователям.
Oscar
same results of oscampo with Smath 0.93, win7
http://www.mediafire.com/?6uf36mq2xc0ykvi
#6 Опубликовано: 06.03.2012 18:15:18
Ok. I'll check it. Thank you.
#7 Опубликовано: 07.03.2012 03:53:51
I think I found the problem. It seems it is again regarding Optimization
Look at the first picture please:
The blue line is a function of x, as in the Oscar's example. The red line is plotting two column vectors. I used the larger step just to see the difference. Either way the q1(x) has been calculated wrong.
Here is another picture with Numerical optimization applied on both q1(x) and for loop.
This time q1(x) has been calculated correctly. Unfortunatelly, the function plot is still wrong and I do not know how to change this.
Actually there is a way by using eval()
But another problem appeared. I can not see why the error in the third plot. Separate plot are possible but not the joined plot? Could someone try to reproduce or to explain this, please. Here is the file Oscarplot.sm
#8 Опубликовано: 19.03.2012 17:58:03
Fixed.
Oscar Campo 19.03.2012 22:22:00, Radovan Omorjan 20.03.2012 03:33:00
