augment -symbolic -numeric -plot crash?
augment -symbolic -numeric -plot crash? - Сообщения
#1 Опубликовано: 27.01.2012 16:05:10
Hello ,
Here is another problem I bumped into. This is a part of the file:
Quite strange that augment itself produces a two column matrix but the assignment to a variable produces a nested matrix with two column matrix. I did not understand this and just tried to change the Optimization. It is Symbolic as you could see. When I change it to Numeric, everything was Ok:
The most problematic thing here is that If we just did not think to much and just put the YX variable in 2D plot, crash occurred:
Here is the SMath file augment-symb-num.sm. Hope that this is not only on my computer.
#2 Опубликовано: 01.02.2012 14:07:16
Crash is fixed. Further work will be performed.
Radovan Omorjan 01.02.2012 15:26:00
