Unit conversion from -1 Celsius to Kelvin
Unit conversion from -1 Celsius to Kelvin - Temperature Unit Conversion - Сообщения
#1 Опубликовано: 09.12.2025 05:44:16
Chulsoon Shin
Chulsoon Shin
In Smath Solver, I guess -1℃ is treated as -1 × 1℃ → -1 × (273.15K + 1K) → -274.15K, not (273.15K - 1K) → 272.15K.
Is there any way to put in the negative sign, not minus?
#2 Опубликовано: 09.12.2025 05:48:33
Chulsoon Shin
Chulsoon Shin
I found the caution with negative numerical values in the Introduction Manual.
-1℃ to be put as (-1)℃ for correct calculation.
#3 Опубликовано: 09.12.2025 13:45:52
1 334 сообщений из 2 249 понравились пользователям.
I don't know what introduction manual you refer to (there is no official one), yet this one probably would do: https://doi.org/10.25933/opus4-3370. Section 3.6 is on temperature units, section 3.5 is on frequency and angular velocity. Both they handle common pitfalls for new users.
#4 Опубликовано: 16.03.2026 07:55:56
DaisyJohnston
DaisyJohnston
Thanks for the link! After reading section 3.6, I see why the software behaves this way. However, for quick calculations, is there a standard 'workaround' you recommend to treat 1°C as 272.15K without manually adding/subtracting 273.15 every time?
#5 Опубликовано: 16.03.2026 12:31:27
587 сообщений из 1 360 понравились пользователям.
As already told in #2 in this topic, you can use paranthesis.
