Beta: SMath Studio 0.99.7736 (07 March 2021)
Beta: SMath Studio 0.99.7736 (07 March 2021) - Сообщения
#1 Опубликовано: 07.03.2021 17:18:22
SMath Studio
Изменения, входящие в версию 0.99.7736
Исправления
  • Loading of Area Titles and Region Description fixed;
  • Handling of incorrectly used BR tag in TextRegion fixed;
  • Critical error sometimes happened in TextRegion near line break fixed;
  • Better control of Field content implemented for TextRegion;
  • TextRegion functionality improved (history vs Children Regions, stability, performance).
Разное
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7736.Mono.tar.gz (1,41 МиБ) скачан 2119 раз(а).
SMathStudioDesktop.0_99_7736.Setup.msi (2,29 МиБ) скачан 4601 раз(а).
NDTM Amarasekera 07.03.2021 23:58:00, sergio 08.03.2021 05:38:00, Serg 09.03.2021 06:45:00, Igor Skarine 10.03.2021 10:00:00
#2 Опубликовано: 08.03.2021 08:07:33
Hi. Thanks for the program, and this update. An small issue: Write some text and then put the cursor somewhere in between within that text and hit the right-delete key. When you reach the end of the text, the work DELETE begins to appear several times:
#3 Опубликовано: 08.03.2021 09:34:17
I can easily reproduce it.
What a funny bug, can't keep myself to print several DELETE.
Somebody stop me :d
#4 Опубликовано: 08.03.2021 09:37:10
NDTM Amarasekera
NDTM Amarasekera
Yes.
#5 Опубликовано: 09.03.2021 04:56:13
Oops... I did it again
I've spent so many time on backward compatibility, performance and formatting improvements... even forgot to check the simplest use cases. Sorry.
Will fix it asap. Actually I'm starting to prepare to make a stable release, so I do not plan to do any major code changes until it is done. Small fixes/corrections only.
Thank you!
sergio 09.03.2021 05:27:00, Jason McCool 26.03.2021 22:45:00, Serg 09.03.2021 06:46:00, NDTM Amarasekera 09.03.2021 12:01:00, Alvaro 09.03.2021 16:36:00, Martin_B 09.03.2021 04:58:00, fedeghi 09.03.2021 05:00:00
