1 страниц (6 вхождений)
another unit problem - changing the unit smath adds redundant fractions - Сообщения
as you can see in the example below here is another problem with units in smath.
As a civil engineer I need to have pressure-values to be printed in [kN/m²] and smath
prints results of calculations in [J/m³] by default. When I try to change the unit manually, a redundant expression
in the form of [m³/m³] appears and cannot be deleted. Not only that this does not look nice - this
"new unit" cannot be combined with other values having been define in [kN/m²] by me.
I suspect that there is a logic behind this I don't understand. So please help me if you have a clue.
Thank you, Nilsminimum example.sm (7,1 КиБ) скачан 1177 раз(а).
nothing is wrong with unit handling in this example except your misinterpretation.
my guess is you copy-paste the meter cube and meter square from somewhere else.
you should recheck how you handle with power for your formulas.
regards
minimum_1.sm (7,28 КиБ) скачан 1183 раз(а).
regards
Hello overlord,
you were totally right. I was handling the power wrong... just found out that I have to press the key twice to have it correctly.
Thank you for spending your precious evening time with helping a newbie out.
May the power be with you,
Nils
Nils
Dear,
in my file is experiencing a similar event, I would like, if possible, any tips on the error that I am commenting and a possible solution.
Thank you!
Error_unit.tif (93,77 КиБ) скачан 632 раз(а).
Dear,
Thank you!
Wrotenothing is wrong with unit handling in this example except your misinterpretation.
regards
FBRamires,
You need to set your units in I.2 to (kPa)^2 and units of I.3 to (kPa)^3.
Edit: See this example
example.sm (7,43 КиБ) скачан 1201 раз(а).
