Stable: SMath Studio 0.88 (12 April 2010) - Сообщения
ЦитатаControls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.-
- Units implemented;
- Added ability to use text inside math regions using '"' char;
- Open/Save file types functionality moved to plugins;
- Desktop: Custom Page Setup Dialog created. Added ability to specify Header and Footer for the print pages;
- Added ability to manualy choose Optimization of function and variables definitions: Symbolic optimization, Numeric Optimization, No optimization;
- Dynamic Assistance performance improved;
- Dynamic Assistance improved: case sensitive search implemented and added ability local variables of the functions definitions to be shown in the Dynamic Assistance items list;
- Added new Example File: "Arabic to Roman numeral conversion";
- New functions added to the SpecialFunctions built-in plugin: importData(..), str2num(), num2str(), concat(..), findstr(.), substr(.), substr(..), strrep(..), strlen(), IsString() and error();
- Numeric library evaluation speed improved (up to 3-6 times, according to task);
- Desktop: Fixed permissions issues on write update setup to Program Files folder on Windows Vista and Windows Seven;
- Desktop: Examples Dialog improved to prevent critical errors when no "examples" directory exists and some other minor improvements done;
- Insert Unit Dialog implemented;
- Desktop: Examples of the Examples Dialog can be opened using DoubleClick on the selected document title;
- SM file format updated (files created or saved with 0.88 version cannot be fully opened using previous versions of SMath Studio);
- Smooth Controls location changing performance improved;
- Function line(..) now returns last line value;
- Added ability to move selected Controls using Left/Right/Up/Down keyboard buttons;
- Main application Icon updated;
- Copy/Paste operations now works with standard SMath Studio separators ('.' as Decimal Symbol and ',' as Arguments Separator);
- Functions rfile(..) and wfile(..) improved/fixed;
- Large arguments of sin(..), cos(..), tan(..) and cot(..) functions forbidden;
- Fixed error in Math Reference Book;
- Fixed error when program cannot find Symbolic result of inverse matrix;
- Desktop: Fixed issue with invisible controls borders on print out;
- Fixed symbolic differentiation issue when using "Calculation" > "Differentiate" menu item;
- Fixed issue when user presses space bar outside any region (control);
- Fixed width of the Dynamic Assistance menu when functions with arguments presented in the list;
- Desktop: Insert Function Dialog fixed: functions with not defined arguments number now will be shown with one argument into Example field;
- Fixed issue with low-level evaluation plugins when exception message from plugin was hidden from user;
- Fixed issue when symbolic library was not able to simplify expressions like "1^n=1";
- Handheld: Fixed issue with too small height of Dynamic Assistance items on VGA screen devices;
- Fixed simplification errors: tan(x)/cos(x), cot(x)/sin(x), ln(1/Sqrt(2)) and lg(1/Sqrt(2));
- Desktop: Page Setup settings now saves into the settings file on program close;
- Fixed numeric calculation error: "5*'N+10*'kg*'m/{'s^2}";
- Fixed simplification error with "10^1.23456789" and similar expressions;
- Fixed Numeric Library error when determenant of the matrix cannot be find: "det(mat(1,2,0,3,6,0,0,0,0,3,3))=#";
- Fixed issue, when result was presented like "a=a/1";
- Fixed error when some functions was invisible into the Insert Function Dialog;
- Language files updated;
- Refactoring.
- Handheld:
Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, full VGA support, all PPC's, Comunicators and smartphones. - Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Desktop и Handheld (23 languages):
- Handheld (PPC, Communicator, Smartphone):
SMathStudioHandheld.0_88.Setup.cab (Date: 12.04.2010. File size: 2.15MB) - * To install from the device
SMathStudioHandheld.0_88.Setup.cab.zip (Date: 12.04.2010. File size: 475.48KB) - * To install from the device (archive with CAB inside)
SMathStudioHandheld.0_88.Setup.exe (Date: 12.04.2010. File size: 509.76KB) - To install from the PC
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_88.Setup.msi (Date: 12.04.2010. File size: 1.16MB)
SMathStudioDesktop.0_88.Portable.exe (Date: 12.04.2010. File size: 17.24MB) - .Net Framework 2.0 doesn't required
- Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_88.Mono.tar.gz (Date: 12.04.2010. File size: 561.39KB) - last version of Mono distributive required!
** For installation of the program from PC it is necessary to install MS ActiveSync first.
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
To install IND language update to the program, please, just put the downloaded Text_IND.lang file to the lang folder of installation directory of SMath Studio (by default it is C:\Program Files\SMath\SMath Studio) and then start the program.
Thanks to Waluyo Adi Siswanto for this great help!
A small hint for Gentoo Linux users:
For properly work of SMath Studio you must to (re)compile dev-dotnet/libgdiplus package with cairo flag on - otherwise all pull-down menus will be broken and fonts/symbols on workplace will be overlapping.
Sorry for my bad English - my native language is Polish
By the way, one who want to get updated interface translation or check for new available interface languages for SMath Studio can visit this page: http://smath.info/translator/. This web-service also provides an interface to simply correct existing translations or make some new one(s).
Thank you for this program... Thank you for sharing it too...
https://smath.com/wiki/Tutorials.ashx
Thank you Gilberto E. Urroz! It's great! I will advise to read this document to all our users. It's a best place where one can find all the information about how to work with SMath Studio.
Many thanks to you.
Новые сообщения
Нет новых сообщений
