Mono: crash on Ubuntu 16.04
Mono: crash on Ubuntu 16.04 - Сообщения
#1 Опубликовано: 09.11.2017 14:47:09
philippe dalet
philippe dalet
18 сообщений из 34 понравились пользователям.
Hello
I've tested SMathStudio (SMathStudioDesktop.0_98_6520.Mono.tar.gz) on linux
and it can't start.
VERSIONs TESTED
Mono JIT compiler version 5.4.0.201
Ubuntu trusty 1404
Mono JIT compiler version 3.2.8
Ubuntu xenial 16.04
Does anyone know the solution?
Greeting,
Philippe
Sorry, I forgot the error message
smathstudio_startup_error.txt (67,04 КиБ) скачан 1180 раз(а).
#2 Опубликовано: 09.11.2017 18:59:34
Seems this is something I must look at before stable release. I will...
Thank you Philippe!
#3 Опубликовано: 10.11.2017 12:52:57
The same error with 0.98.6522.
#4 Опубликовано: 11.11.2017 07:10:55
philippe dalet
philippe dalet
I found an origin of the crash on linux. The program cannot find a font, exactly MS sans serif.
I have put ms_sans_serif.ttf in ~./fonts. The error message changes.
tested on ubuntu 64 bits 16.04
SMathStudioDesktop.0_98_6523.Mono
Philippe.
Davide Carpi 11.11.2017 13:52:00
#5 Опубликовано: 19.11.2017 19:21:47
It should be fixed in latest beta. Could someone confirm with screenshot please?
#6 Опубликовано: 19.11.2017 20:49:09
SMath seems to ignore "portable.version"
I don't know where userdir is or how to otherwise clean up old plugins.
Показать спойлер
#7 Опубликовано: 20.11.2017 05:14:17
Same stack trace of Martin even in Linux Mint
It should be in ~/.config/SMath or in ~/.SMath
Martin Kraska 20.11.2017 05:43:00
#8 Опубликовано: 20.11.2017 05:44:56
Deleting the plugins doesn't help. Same crash, no matter if I run ./smathstudio_desktop_mono as root or as user.
It would facilitate testing if the portable.version wouldn't be ignored. Plugins are incompatible at times...
