Interaction Diagram for Rectangular Reinforced Concrete Sections (ACI 318)
Interaction Diagram for Rectangular Reinforced Concrete Sections (ACI 318) - Сообщения
#1 Опубликовано: 02.05.2015 04:16:28
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
I've attached a file to generate the Compression and Bending Interaction diagram for rectangular sections, using ACI 318-11.
Any SI and US customary units work, but the results are in kN-m, which can be switched manually if you know where to look.
The rebar area and location column vectors can be made larger or smaller with no effect to the algorithm, So any number of steel layers can be used.
Future work: Expanding on this to include Biaxial Bending using the Reciprocal Load method. I had done this previously with MathCAD, and am currently working on a version for smath. I am having trouble getting it to be done without human input at certain points, but will keep working on it.
Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions.
Updated: Automatic scaling of the plot has been implemented. Also previously the section was treated as compression controlled, now the transition from compression controlled to tension controlled is taken into account.
ioan92 20.06.2015 03:55:00
#2 Опубликовано: 02.05.2015 09:35:54
Ryan Freund
Ryan Freund
Ernesto,
Very nice! Thanks!
Here is one thought I have when creating calculations. With your current setup you can really only use this one calculation on one page, right? Otherwise you would get into trouble of overwriting variables. I have been trying to take the calculation like you have created and turn it into a large function. This way you can use this for multiple beams on a single smath "page" (meaning a single .sm file). I think this is much more efficient especially if trying to print multiple beams/pages. But maybe there is a different way and even using function you have to be careful how you name your variables (the # symbol at the end of the variable seems to be a popular way to do it on smath).
Anyway thanks for posting.
#3 Опубликовано: 02.05.2015 10:10:03
I have reproduced the diagram in Maxima Draw2D with automatic scaling (except for the x ticks, which are hardwired). Also, I parametrized the usage of units in the plot. One might even use radiobutton list regions for unit selection and having appropriate dynamic labels in the diagram.
P-M-Interaction_Kr.sm (182,88 КиБ) скачан 2148 раз(а).
#4 Опубликовано: 02.05.2015 16:34:23
Ernesto
Ernesto
RFreund: I'm also playing around with making it a larger function, but still along the same lines as I currently have it. Just making the functions dependent on more variables. I still want to keep it clear where each step comes from without making it so overly complicated where someone may get lost following it. This way I can add bending in the y-axis more easily. Which would lead me to my next step of incorporating the Reciprocal Load Method for checking biaxial bending and compression. Hopefully I will get around to doing that soon. I will post it once I get everything working correctly in biaxial bending.
I am wary of making a sheet that does multiple beams on the same sheet, as that takes away from the clarity of the calculations. This is another challenge of itself, scaling these things up in a way that someone else can follow what you are doing to audit your calculations. My objective is not to make a black box where things magically appear, but clear steps where other engineers can easily verify my work.
mkraska:
Thanks for taking the initiative with the plot! The scaling looks great. I don't have any experience with the Maxima Draw2D and am carefully checking out your code to see what I can get out of it.
Thanks again!
#5 Опубликовано: 03.05.2015 17:31:31
Ryan Freund
Ryan Freund
Ernesto: Yes that is the 'rub' I suppose. I started using Smath to create very clear/comprehensible calculations. Now that they are clear I am trying to turn them into a black box (or so it seams), which would be more geared towards production. However, the advantage is that there is the option to view the "code" behind the black box. In any case good work!
I have the motivation to create a more general "rigorous" axial and biaxial bending function but just don't seem to have the time.
#6 Опубликовано: 19.06.2015 22:29:01
Ryan Freund
Ryan Freund
Ernesto:
I'm curious how you chose (h.x * 1.4) * 0.005m for the interval of iteration?
#7 Опубликовано: 20.06.2015 12:08:20
Ernesto
Ernesto
RFreund: I updated the file just now with the reasons described in the first post.
I actually increased it to (h.x*1.6)*0.005m. I chose the interval (0.005m) just so the plot wouldn't look sluggish for small sections. Another way to do this is based on the percentage of the section size so there would be the same number of data points for small sections as large sections, this would probably be more efficient but didn't think of it at the time .
The range for the iteration (1.6) was chosen from trial and error, trying different section sizes and verifying if the range was adequate (if all the data points required to complete the plot were generated) , while at the same time keeping the range as small as possible to save on computing time.
I was thinking about what you said before about checking various columns in one sheet. One way I was playing with is to have one sheet for one section size, but used in multiple column locations so there would be different loads to check, and plotting those points to see if they are in the envelope or not. But with the X-Y plot I'm using, I haven't figured out a way to differentiate those points with one another (with labels or in the legend). (see attached image).
#8 Опубликовано: 03.07.2015 20:17:47
Ryan Freund
Ryan Freund
Thanks for the Response Ernesto.
You know, another nice feature would be if there was a way to check if the point falls within the curve, then return an "OK" or "NG" or something along these lines. Of course it is easy enough to visually compare but it would still be neat.
I've attached a spreadsheet which is for masonry shear walls, but they use a close range liner interpolation technique it seems.
Axial_and_Flexure.xls (134,5 КиБ) скачан 1431 раз(а).
#9 Опубликовано: 04.07.2015 05:25:16
To accomplish the task you can use the even-odd rule.
Attached an example.
Check.sm (15,7 КиБ) скачан 1797 раз(а).
#10 Опубликовано: 18.07.2019 10:59:52
Joe_Jones
Joe_Jones
I need a compression and bending interaction diagram for my master's dissertation. I have downloaded the file and input the values of my column into the smath sheet. However. when i recalculate the page, it does not update the diagram.
How do i update the diagram to match up with my input data?
Any help would be appreciated.
#11 Опубликовано: 18.07.2019 12:15:57
With X-Y Plot
P-M-Interaction_Kr.sm (48,25 КиБ) скачан 1945 раз(а).
#12 Опубликовано: 20.10.2019 23:21:04
ezstr
ezstr
With X-Y Plot
P-M-Interaction_Modify.sm (60,48 КиБ) скачан 1712 раз(а).
The smath sheet you provided is very useful.
I have a question.
1) An error occurs when the length of the column becomes longer.
ex) hx = 4000 mm
2) I want to find n value that satisfies Pnx = pu.
when I use the solve() function, an error occurs.
Is there a way to fix it?
how can find n value ?
Please refer to the attached sheet
#13 Опубликовано: 21.10.2019 01:47:56
Hi.
I have a question.
ex) hx = 4000 mm
The formulae for apply is valid only for certain ranges. You can see that the surface is outside the required range (by the norm), so, the SMath error actually is irrelevant: what it's important is the red in the worksheet:
Solvers are unstables, except maybe for al_nleqsolve. But here, and similar cases, you can implement always your own solver:
#14 Опубликовано: 21.10.2019 09:24:53
when Iuse the solve() function, an error occurs.Is there a way to fix it?
... more solvers in there.
Solve Dichotomy.sm (19,94 КиБ) скачан 1665 раз(а).
Solve roots Newton-Raphson.sm (51,33 КиБ) скачан 1702 раз(а).
Solve roots_solve RootSecant (1).sm (104,62 КиБ) скачан 1730 раз(а).
#15 Опубликовано: 22.10.2019 21:18:16
ezstr
ezstr
Thank you for your answer.
Have a nice day.
#16 Опубликовано: 23.08.2023 22:45:53
Fabian Valencia Villaquiran
5 сообщений из 3 понравились пользователям.
I had made my own code, but I was missing graphing, I took as a guide the code previously published here and additionally I added the graph the cross section of the column and the load combinations P-M, it would be missing to add the steel bars to that section to have a better graphical interface.
I will work to complement the code with bresler's reciprocal load method.
Diagrama de interaccion.sm (848,38 КиБ) скачан 1881 раз(а).
churichuro 24.08.2023 12:48:00, oscar mauricio 07.04.2024 10:53:00
