Type conversion error
Type conversion error - Сообщения
#1 Опубликовано: 13.05.2020 08:30:08
Eugene
Eugene
Does anyone know how to solve this error?
#2 Опубликовано: 13.05.2020 11:18:01
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. The error came from try to compare the vector time1 with the scalar T(1,1) in the first if. Maybe with the vectorization operator you can solve the issue, evaluating vectorize(rel(time1)).
If not, you can try to modify the code with a loop for each element in the time1, like in this example:
frapuano 13.05.2020 13:56:00
#3 Опубликовано: 14.05.2020 03:33:37
Eugene
Eugene
Thanks. First one didn't work. Will try to add a loop as you suggested.
#4 Опубликовано: 14.05.2020 06:55:34
From a complex vector.
#5 Опубликовано: 14.05.2020 07:43:21
Also, you might use vectorize(rel(time1)) to apply the scalar function at each time1 value.
#6 Опубликовано: 14.05.2020 15:22:11
More in there as cumulative.
Vector Cumulative.sm (24 КиБ) скачан 53 раз(а).
