DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Сообщения
#21 Опубликовано: 01.08.2018 12:54:24
Simple test 2.
DotNumerics.ode.test2.sm (21,23 КиБ) скачан 1677 раз(а).
DotNumerics.ode.test2.pdf (79,99 КиБ) скачан 807 раз(а).
sergio 01.08.2018 18:06:00, Radovan Omorjan 02.08.2018 03:05:00
#22 Опубликовано: 01.08.2018 21:57:14
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24,51 КиБ) скачан 1767 раз(а).
#23 Опубликовано: 09.09.2018 14:23:36
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23,66 КиБ) скачан 1823 раз(а).
frapuano 09.09.2018 17:18:00, Вячеслав Мезенцев 10.09.2018 05:37:00
#24 Опубликовано: 10.09.2018 06:48:25
Updated for SS 0.99.6824. Intervals issue fixed.
sergio 10.09.2018 07:02:00, frapuano 10.09.2018 09:23:00, NDTM Amarasekera 10.09.2018 09:48:00
#25 Опубликовано: 06.12.2018 14:42:53
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 Опубликовано: 24.12.2018 09:13:53
Updated.
2018-12-24_17-06-48.png 2018-12-25_04-33-23.png 2018-12-25_04-34-24.png dn.ode.test2.png dn.ode.test1.png 2018-12-24_17-07-41.png
dn.ode.kinetic1.sm (8,26 КиБ) скачан 1916 раз(а).
dn.ode.kinetic2.sm (12,59 КиБ) скачан 1796 раз(а).
dn.ode.kinetic3.sm (12,28 КиБ) скачан 1846 раз(а).
dn.ode.test1.sm (19,58 КиБ) скачан 1861 раз(а).
dn.ode.test2.sm (18,88 КиБ) скачан 1836 раз(а).
dn.ode.Amplitude detector.sm (20,17 КиБ) скачан 1890 раз(а).
dn.ode.kinetic1.pdf (77,42 КиБ) скачан 1044 раз(а).
dn.ode.kinetic2.pdf (93,05 КиБ) скачан 980 раз(а).
dn.ode.kinetic3.pdf (91,31 КиБ) скачан 964 раз(а).
dn.ode.test1.pdf (115,72 КиБ) скачан 942 раз(а).
dn.ode.test2.pdf (120,44 КиБ) скачан 933 раз(а).
dn.ode.Amplitude detector.pdf (148,87 КиБ) скачан 987 раз(а).
NDTM Amarasekera 24.12.2018 09:44:00, sergio 24.12.2018 11:04:00, frapuano 24.12.2018 14:23:00, Radovan Omorjan 24.12.2018 14:52:00
#27 Опубликовано: 25.12.2018 14:49:08
Native works as well.
You can try rkfixedSteven.
#28 Опубликовано: 25.12.2018 16:25:11
frapuano 25.12.2018 19:01:00
#29 Опубликовано: 09.12.2021 09:10:25
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 09.12.2021 11:40:00
#30 Опубликовано: 20.12.2021 16:18:13
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Опубликовано: 21.08.2022 02:43:28
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8,42 КиБ) скачан 1668 раз(а).
#32 Опубликовано: 22.08.2022 03:12:45
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
sergio 22.08.2022 04:19:00, Alvaro 23.08.2022 20:15:00
