[SS-2274] Save as XMCD
[SS-2274] Save as XMCD - Сообщения
#1 Опубликовано: 17.06.2015 18:14:09
Jure
Jure
Hi! I want to save my smath file in to MathCAD file.
While i want to open it in MathCAD i get an error
ERROR
Does anybody have an idea how could i solve this problem?
If it helps im attachin also .sm file to see
GLULAM
#2 Опубликовано: 17.06.2015 19:09:22
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
Worked for me. File attached.
Dimenzioniranje_GLULAM_2012-10-18.xmcd (90,37 КиБ) скачан 1345 раз(а).
#3 Опубликовано: 18.06.2015 13:58:53
Jure
Jure
Thank you man! dont understand what the problem on mine side is
#4 Опубликовано: 18.06.2015 18:50:45
I think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted.
test_second.xmcd (90,37 КиБ) скачан 1211 раз(а).
#5 Опубликовано: 15.07.2015 17:01:57
Macs
Macs
1 сообщений из 13 понравились пользователям.
Hi, i have the same problem, anyone knows how repair the document?
#6 Опубликовано: 15.07.2015 17:03:03
Macs
Macs
Yes, the first open with mathcad and the seccond fail... How u repair?
#7 Опубликовано: 16.07.2015 14:57:03
Thank you for the feedback!
I've already reported it as SS-2272.
The settings used by the plugin to save the XMCD file are your system settings (comma as decimal separator, when you get the error). Until a new version of the plugin will be available, you have to change your system settings before launching SMath and then you can save the file. Otherwise the file must be opened with a text editor and you have to fix the xml attributes.
#8 Опубликовано: 20.07.2015 10:06:05
Macs
Macs
Thanks for your help, but i change the system settings and the problem is still on. I hope the new version of the plugin be avaible soon to use the Smath with all computers in the job (i'm trying to convince my boss )
See u soon guys, the program is excelent keep in that way!!
PD: The file is attached
#9 Опубликовано: 20.07.2015 10:44:47
You can try if this works... maybe there is another error...
P.S. just to be sure, for "system settings" I mean the OS settings (in Windows 7: Control Panel > Regional and Language Options > Formats > Additional settings)
Compuerta Desripiadora - Max.xmcd (76,41 КиБ) скачан 1209 раз(а).
#10 Опубликовано: 20.07.2015 11:35:49
Macs
Macs
"OS settings"
Thanks!!!! The problem was solved, u rocks!
#11 Опубликовано: 18.08.2015 12:15:07
Macs
Macs
Hi people me again...
I have a new problem when i save as .xmcd
Attached image and document
Like always, thanks!
Compuerta Túnel - LH1 - 2 Hojas.sm (1,61 МиБ) скачан 32 раз(а).
#12 Опубликовано: 18.08.2015 16:45:55
Macs
Macs
4 downloads and no reply... this is serious jejeje
#13 Опубликовано: 18.08.2015 17:25:41
Ernesto
Ernesto
Its an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error?
Davide Carpi 18.08.2015 19:27:00
#14 Опубликовано: 19.08.2015 09:58:57
Macs
Macs
Hehehe, I have been very busy in this sheet ... To find the error, I did yesterday the same like you (copy to a new piece by piece sheet and save XMCD), and the problem was edited image, when the delete the problem is resolved.
Now you know, dont edit images if you want to save XMCD.
Have a nice day, and thanks!
#15 Опубликовано: 19.08.2015 12:34:11
This is not completely true, seems the problem is just on the state of the images. If you uncheck the "edit" button everything goes fine.
Bug added in the BTS: SS-2274
Compuerta Túnel - LH1 - 2 Hojas_fixed.sm (1,6 МиБ) скачан 33 раз(а).
#16 Опубликовано: 26.04.2016 08:42:18
Fix committed, should be available in the next relase.
SS-2274 updated.
