1 страниц (5 вхождений)
"Not defined" but it is defined - Сообщения
Often SMath has a red box around something and says "x not defined" when I hover over it, but x is defined. In this case, the problem is that I typed "In" instead of "in", so it should be saying "In not defined", but it says "Req not defined", which seems like a bug to me.
Also, congrats on being able to handle units like "nV/√Hz" without screwing up.
Please could you post an example? It will help to debug and make a fix. Thx.
WrotePlease could you post an example? It will help to debug and make a fix. Thx.
Req not defined.sm (17,68 КиБ) скачан 1262 раз(а).
Is this bug: SS-89
Fixed in the scope of http://smath.info/bts/Issues/IssueDetail.aspx?id=89
Fix is available in the latest nightly build of SMath Studio.
Many thanks and best regards!
Davide Carpi 06.07.2014 17:55:00
