Format - Sections of Page
Format - Sections of Page - How to create separate calc sections - Сообщения
#1 Опубликовано: 09.10.2013 14:24:04
Ryan Freund
Ryan Freund
A few questions in regard to formatting really:
1. Is there a way to create separate calcs sections so that the variables would lose any associations below a certain point on the page?
2. If there is a way to execute 1. above. Then can you create different levels of variables (i.e. global vs local to the section)?
3. Any way to create a table of contents? An automatic one preferably. :d
I suppose, if these are not possible, consider these feature requests...?? :d :d
Really starting to like Smath, btw...good job to those involved.
#2 Опубликовано: 09.10.2013 19:09:33
You can sort of delete existing variables (not functions) using the Clear() function from the Custom Functions plugin. It, however, does not completely remove the variable but just assigns a non-evaluable value.
3.
You can use collapsible area regions to structure your documents. See for example the function index in the Activebook help system. It would require much scrolling, therefore I subdivided it into groups of functions. Such regions can be nested.
Clear.sm (42,93 КиБ) скачан 1387 раз(а).
#3 Опубликовано: 09.10.2013 22:59:42
Ryan Freund
Ryan Freund
MKraska - Thanks for the info.
I do like the collapsible area regions for working in SMath. I'm just trying to see how I can better format the end result. I usually need a Table of Contents, which can be cumbersome to manually produce, so I thought I'd ask.
Thanks again for the suggestions.
#4 Опубликовано: 10.10.2013 02:57:08
Actually area regions are the closest things to a structured summary.... Btw I think that this would be an interesting feature, maybe extending the attributes of text regions.
You could make this request in the "feature requests" section.
