error in inverting matrix
error in inverting matrix - Сообщения
#1 Опубликовано: 11.02.2010 15:28:00
buenos
buenos
hi
i was trying to invert a matrix with smath winxp 2010-feb10 version.
It gives me an error that "matrix is noninvertible (determinant equals zero)".
the determinant is not zero, i have checked. i have tried the M^-1 and invert(M) too. but gives the same error.
if i do this, then it works, calculates the result:
M:=...
M^-1= RESULT
if I do this, then it does not work:
M:=...
M2:=M^-1
M2= ERROR
#2 Опубликовано: 11.02.2010 15:46:07
buenos
buenos
M=1/sqrt(2)*mat(1,-1,0,0,0,0,1,-1,1,1,0,0,0,0,1,1,4,4)
det(M)=-1 so it is not zero
if i change the matrix, to get a different determinant, not -1, then it wors.
#3 Опубликовано: 11.02.2010 15:49:04
Hello.
I can't reproduce this error with my matrices:
Could you please send your full example to support[at]smath[dot].info?
Best regards, Andrey Ivashov.
#4 Опубликовано: 11.02.2010 15:53:19
OK, I see now, thanks. Will check in 5 hrs.
#5 Опубликовано: 11.02.2010 21:01:07
Figured out that this error was in previous versions of SMath Studio as well when trying to evaluate symbolically:
[MATH](1/sqrt(2)*mat(1;-1;0;0;0;0;1;-1;1;1;0;0;0;0;1;1;4;4))^{-1}—#[/MATH]
Starting work to fix it.
#6 Опубликовано: 11.02.2010 22:01:01
buenos
buenos
ok,
thanks.
#7 Опубликовано: 15.02.2010 01:18:02
Here is modified version of SyLib.dll file for SMath Studio 0.87 where this bug fixed: https://smath.com/files/Download/hkzMV (just unpack it and replace original SyLib.dll from Program Files/SMath/SMath Studio folder).
You can use it till next version of the program will be released.
