1 страниц (6 вхождений)
Euler works - Runge-Rutta not - Why? - Сообщения
EK45 was Deified by Mathematica
Working code included.
Rocket-s-Euler.sm (122,44 КиБ) скачан 1522 раз(а).
Thanks.
I have corrected myself
Rocket-s-Euler-RK.sm (87,35 КиБ) скачан 1424 раз(а).
New question
Why this not works
Rocket-s-Euler-RK-full.sm (88,8 КиБ) скачан 1476 раз(а).
New question
Why this not works
Your RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Rocket-s-Euler-RK-full.sm (89,85 КиБ) скачан 1487 раз(а).
Valery Ochkov 31.12.2023 17:02:00
WroteYour RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Tanks!
Send me please the corrected file.
WroteWroteYour RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Tanks!
I've now added the corrected file to my earlier reply.
Valery Ochkov 31.12.2023 17:43:00
