New homepage
New homepage - Сообщения
#1 Опубликовано: 08.08.2014 12:04:50
IVR 08.08.2014 15:55:00, Andrey Ivashov 14.08.2014 15:02:00
#2 Опубликовано: 14.08.2014 14:59:53
I'm glad you've noticed it
There are plenty of improvements done to this page last days: page is multilingual (for now it supports ENG and RUS), SEO optimized, supports all popular browsers, it's code is fully standardized (HTML5) and it always shows latest versions of SMath Studio and all extensions (data source is the same as used for Extension Manager). Web-page supports landscape and portrait displays (try to play with browser window width) - useful on some tablets.
One more important change made for urls to all files. No sequenced integer ids used anymore! Instead you can see short (5 chars) random file id. So, previously we had smath.info/?file=999999 and now it is changed to smath.info/file/aBcD5 (or, optionally smath.info/file/aBcD5/fileName.ext). This is important change because it makes brute force strategy for requesting files much harder. Another profit is that urls made a bit shorter, so it is easy to share them by typing or even in memory (similar chars like 0 and O, 1, I and l and others are not used)
And now we have 3 domains:
All of them are pointing to the same web-page. Primary domain is smath.info.
I'm very glad I have a progress with project's home page. I will continue improve it... any suggestions?
Best regards, Andrey Ivashov.
Davide Carpi 14.08.2014 19:17:00, Вячеслав Мезенцев 15.08.2014 01:01:00, IVR 15.08.2014 04:11:00
#3 Опубликовано: 15.08.2014 06:46:10
I like the clean design of the home page (with as few formatting as possible).
There still is an error in the example images (as reported here), possibly just wrong translation to english (the russian version just says "Moment about x/y" instead of "Moment of intertia" which is in conflict with the units shown).
#4 Опубликовано: 15.08.2014 15:50:49
Thank you, Martin! I will fix this example.
