problem with "str2num"
problem with "str2num" - the function is not evaluated correctly - Сообщения
#1 Опубликовано: 17.06.2019 13:36:00
I need to evaluate a condition (Boolean) that I have to build on a case-by-case basis. In testing this situation, I experienced the incorrect behavior of the "str2num" function in the case of the "=" sign.
str2number_z.sm (4,22 КиБ) скачан 1292 раз(а).
#2 Опубликовано: 17.06.2019 20:22:08
Clearly a bug it does not recognize 'Numeric'
#3 Опубликовано: 17.06.2019 20:42:28
Try this.
sergio 18.06.2019 06:14:00, NDTM Amarasekera 18.06.2019 06:20:00
#4 Опубликовано: 18.06.2019 05:36:23
thank you uni, it's a good buffer solution; only a minimum discomfort remains for entering the correct character.
