Issue with finding derivative
Issue with finding derivative - Сообщения
#1 Опубликовано: 22.02.2009 21:24:41
Adrian Stachowiak
Adrian Stachowiak
I was just playing with the software and it looks promising, but I cannot say that it is reliable right now. While checking out differentiation option I found an error. On the screen you can see 3 different calculations and second one gives wrong result.
#2 Опубликовано: 22.02.2009 23:08:01
2270 сообщений из 3734 понравились пользователям.
Hello. Thank you for the report.
This error in symbolic module of the SMath Studio was already found and fixed:
New version of the program will be available on the end of February.
#3 Опубликовано: 10.03.2009 17:35:37
c_roumilhac
c_roumilhac
Hello there,
You did a great piece of work here, and I think I found out a problem.
Sorry but I can't post an image of it.
I compute the following
derivative of (exp(1/x)) and derivative of (exp(x^-1)) I'm expecting the same output but I got for the first one :
-exp(x)/x^2 and for the second one -exp(1/x)/x^2.
The version I'm using is windows 0.78 b3347 and I reproduced it also on the handheld version.
Thanks in advance,
C.
#4 Опубликовано: 10.03.2009 22:52:17
Thanks for the report. I've got the similar finding from the russian user of SMath Studio this week. Error reproduced, will be fixed asap.
