Closed Area and red cursor
Closed Area and red cursor - The red cursor is acting weird if a closed Area is visible on the screen - Сообщения
#1 Опубликовано: 02.02.2018 11:38:39
Istvan Szarka
Istvan Szarka
Hello
The problem is with SMath Studio Desktop 64, 0.98.6606
If there is a closed Area region on screen the small red cross is not moving if the arrow keys are used or if Enter is pressed.
It actually moves, but it remains at the same place on the screen.
If the closed Area is not visible (eg. after scrolling down) there is no problem
If the Area is open, there is no problem either
Istvan
#2 Опубликовано: 02.02.2018 12:46:26
Confirmed. Applies to the classic view mode only.
#3 Опубликовано: 14.02.2018 07:54:38
Istvan Szarka
Istvan Szarka
Hi
It seems something is still not perfect in 64bit, 0.99.6611 on Win10
Somehow the red cross is not updated if a closed area region is visible on the screen, if I scroll and it goes out from the screen, then everything is OK.
In this file cursor keys.avi (1,72 МиБ) скачан 402 раз(а). I try to move the cross with the cursor keys, first with the closed area visible, second when it is not.
Something very similar happens when Enter is pressed
#4 Опубликовано: 14.02.2018 14:26:11
2 343 сообщений из 4 044 понравились пользователям.
Hello.
Please check if you can reproduce this with latest SMath Studio 6619.
#5 Опубликовано: 11.03.2018 11:48:26
Istvan Szarka
Istvan Szarka
Hello
Thanks, it is definitely fixed in 6622
Istvan
