Repeating calculations
Repeating calculations - Сообщения
#1 Опубликовано: 11.04.2013 16:48:07
kilele
kilele
Hi, this is a sample made by Radovan on how to repeat calculations but using mat2sys and sys2mat from the customFunctions plugin
Another way of creating tabular data.
repeating_calculations3.sm (9,69 КиБ) скачан 1405 раз(а).
Radovan Omorjan 12.04.2013 04:17:00, Davide Carpi 12.04.2013 06:52:00
#2 Опубликовано: 11.04.2013 17:50:05
1 355 сообщений из 2 269 понравились пользователям.
Some care is required when creating tables by application of functions to lists (systems).
If more than one list or more than one occurance of a list is involved in the expression to apply, then the resulting list contains all possible combinations of elements from the individual lists and the resulting length is a power of the input list length.
There may be unexpected effects of symbolic optimization of the function definition. At least, symbolic and numeric optimization may result in different list sizes.
In the example, symbolic optimization results in storage of 2*x instead of x+x thus reducing the number of list occurences and thereby the size of the result.
listen.sm (7,96 КиБ) скачан 1399 раз(а).
#3 Опубликовано: 11.04.2013 18:33:40
kilele
kilele
Thanks! so I was quite wrong as of suggesting systems to create tables.
It is error-prone because most of the time one wants to compute several lists on the same expression.
Radovan Omorjan 12.04.2013 04:18:00
#4 Опубликовано: 14.04.2013 05:51:21
I would not go that far to say the suggestion was wrong. The procedure is safe and convenient as long as you know what you are doing. However, people just seeing such examples may wrongly generalize to expressions with multiple list occurences. It would help a lot if implicit looping with index vectors just as in Mathcad was available.
