1 страниц (3 вхождений)
Solving overdetermined systems of linear equations - Сообщения
#1 Опубликовано: 25.11.2016 16:08:21
I was reminded by the posts in, New variable programmatically; also: Solving under/over defined system of linear eqautions,
that I'd recently used an algorithm for overdetermined systems that I'd unearthed in Wikipedia:
I've documented it's use very simply so that even I'll know how to use it next time it's needed. (memory gets a lot worse with age
) Perhaps others will find it useful.
https://smath.com/wiki/GetFile.aspx?File=LinearEquationSystems.sm
Brian
Brian
frapuano 25.11.2016 16:27:00, Alexander O. Melnik 25.11.2016 18:09:00, Davide Carpi 25.11.2016 19:18:00
#2 Опубликовано: 25.11.2016 18:11:04
Thanks alot; always good toclean up a worksheet from unnecessary plugin calls.
#3 Опубликовано: 25.11.2016 19:52:59
The β snippet represents the 'Cholesky' solver, used directly
for fitting polynomials to noisy data set. It is also the basic
solver in association with the "Conjugate Gradient".
bdrunagle 26.11.2016 04:57:00
Новые сообщения
Нет новых сообщений
