Solving tricky functions
Solving tricky functions - Hertzian contact stress - Сообщения
#1 Опубликовано: 20.10.2022 11:38:20
ryno
ryno
Good day everyone,
I am building a Hertzian stress calculator and got stuck at the step where I calculate the k value for a particular B/A reationship.
Any help will be appriciated
contact stress calc.sm (22,69 КиБ) скачан 1215 раз(а).
#2 Опубликовано: 20.10.2022 11:48:46
ryno
ryno
We also know than K will always be in the range (0,1)
The equations presented above is obtained from the book Advanced Mechanics of Materials by Boresi Et al
#3 Опубликовано: 20.10.2022 17:34:39
In case of these functions, al_nleqsolve() can be the answer.
No other solver is capable other than al_nleqsolve().
k' should be under line, otherwise not solveable.
Here is your function solved.
contact stress calc_1.sm (28,28 КиБ) скачан 1265 раз(а).
Click to enlarge Click to enlarge
NDTM Amarasekera 21.10.2022 09:20:00, sergio 21.10.2022 05:43:00, Alvaro 24.10.2022 00:51:00
#4 Опубликовано: 21.10.2022 07:52:33
Laurent Fournier
Laurent Fournier
I'm super impressed !!!
#5 Опубликовано: 23.10.2022 16:46:37
Your original document is circular and indigestible.
From un-sourced [K,E] and arbitrary datum ... solve.
This sample is not appropriate.
As you have said, it is only solvable when K and E already given.
roots() can't solve without K and E given or calculated separately.
And you can't calculate K and E while not knowing what k is.
Your sample is not what OP wants.
He means to solve that complicated Q function.
Without any parameter or variable of K and E are pre-given.
Oscar Campo 23.10.2022 20:58:00, Alvaro 24.10.2022 00:51:00
#6 Опубликовано: 24.10.2022 09:26:26
With elliptic integrals from GSL and Cephes library.
Alvaro 26.10.2022 14:25:00, Oscar Campo 24.10.2022 11:14:00, sergio 25.10.2022 14:02:00
#7 Опубликовано: 24.10.2022 20:29:42
Oscar Campo
Oscar Campo
Good day everyone,
Solving by the old bisection method:
contact stress calc_by_bisection.sm (26,36 КиБ) скачан 1222 раз(а).
sergio 25.10.2022 14:02:00, Alvaro 26.10.2022 14:25:00
#8 Опубликовано: 25.10.2022 12:01:21
Solving with a custom algorithm.
contact stress calc_2.sm (21,66 КиБ) скачан 1245 раз(а).
Oscar Campo 25.10.2022 12:07:00, sergio 25.10.2022 14:02:00, Вячеслав Мезенцев 25.10.2022 12:43:00
#9 Опубликовано: 25.10.2022 12:08:25
Oscar Campo
Oscar Campo
Very elegant!
#10 Опубликовано: 28.10.2022 08:38:03
... slightly refreshed/augmented
Absent of comments from Originator !
Cheers ... Jean.
Solve Circular Elliptic Datum Native Copy.sm (68,97 КиБ) скачан 1289 раз(а).
