How to Hard Define a Variable with Combobox
How to Hard Define a Variable with Combobox - How to set a variable equal to a value as if manually input using a combobox - Сообщения
#1 Опубликовано: 12.02.2016 23:19:12
Ryan Freund
Ryan Freund
I like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!!
#2 Опубликовано: 12.02.2016 23:40:38
Interesting, but "Insert Combo box" crashes Smath 5346 ! ?
Davide Carpi 13.02.2016 07:25:00
#3 Опубликовано: 13.02.2016 07:50:44
Thanks!!
As for now there aren't workarounds from user-side. Probably a dirty solution (DEV-side) would be to provide an access to the output values in the xml with an "hook tag" for include. However the content wouldn't be "dynamical".
Merci beaucoup Jean, bug confirmed, source of the pain found. I'll update the plugin ASAP.
#4 Опубликовано: 13.02.2016 15:48:43
Ryan Freund
Ryan Freund
I see, I'll keep watch for any updates.
Thanks!
