Unexpected error
Unexpected error - Сообщения
#1 Опубликовано: 06.09.2012 11:59:13
Samira
Samira
Hi everybody,
I am a very new user of SMath. I created an sm file for calculating stiffness matrix of a beam. After I ran the program I was trying to change one input format and I suddenly closed the sm file before it finished calculating. After doing that I am no more able to open my previous sm file. The error message is " Unexpected end of file has occurred. The following elements are not closed: result, math, region, regions. line 46280, position 26".
If anybody know how to retrieve the old file Please help me.....
#2 Опубликовано: 06.09.2012 15:20:16
Infinity
Infinity
3 сообщений из 30 понравились пользователям.
Hi Samira,
I already faced the same problem. If you do not have a backup, there is no way to restore the file.
This is a bug within SMath. Avoid saving the worksheet while it is calculating or train yourself to click the "Interrupt processing" button before you click the save button.
Infinity
#3 Опубликовано: 06.09.2012 18:08:51
Hi everybody,
Please attach your damaged file to the post, we can recover a part of it (see here)
regards,
w3b5urf3r
#4 Опубликовано: 30.09.2015 06:15:19
Dane van Tonder
Dane van Tonder
Hi
I have a similar error my file wont open with the unexpected end of file error.
I have attached it if possible it will be appreciated if you could try recover it.
Dane
Portal Design SANS.sm (1,38 МиБ) скачан 1383 раз(а).
#5 Опубликовано: 30.09.2015 08:28:57
Done!
Portal Design SANS_RECOVER.sm (1,38 МиБ) скачан 1387 раз(а).
#6 Опубликовано: 30.09.2015 23:31:10
Crashing unexpetedly is not particular to Smath.
Often, it's not possible to trace the cause.
In that respect, Smath is superior to Mathcad,
you lose only what has not been saved, but that
may depend upon your PC version. With XP, the
most recent restore point is not far from where
it crashed.
jmG
