RC: SMath Studio 0.99.7818 (28 May 2021)
RC: SMath Studio 0.99.7818 (28 May 2021) - Сообщения
#1 Опубликовано: 28.05.2021 12:18:11
2270 сообщений из 3734 понравились пользователям.
Changes introduced in current build 0.99.7818
Улучшения
  • SMath Viewer apps extended to support Save/Open functionality (allows to load initial data to the app and extract calculation results from it);
  • Text Region improved to accept input from right toolbar buttons and Insert Function dialog;
  • Equation parts can now be pasted to Text Region from Clipboard (can be turned/off/on using conext menu: Automatic replacement > Clipboard).
Исправления
  • Locale related issues fixed in Math Region (appears on paste and when it is shown inside Holder Region, f.e. as a part of Plot Region);
  • Handling of the plug-ins failed to be updated automatically improved;
  • Math Region prioritized to handle Paste from Clipboard operation first.
Разное
  • Support for Document mode improved (Page break Area Region made invisible; inactive area under the page break is not highlighted by color anymore);
  • Text Region improved (better handling of Backspace; better back-compatibility; critical issues fixed);
  • Refactoring.
Download
SMathStudioDesktop.0_99_7818.Mono.tar.gz (1 МиБ) скачан 703 раз(а).
SMathStudioDesktop.0_99_7818.Setup.msi (2 МиБ) скачан 2192 раз(а).
Вячеслав Мезенцев 28.05.2021 12:21:00, sergio 28.05.2021 12:56:00, NDTM Amarasekera 28.05.2021 13:06:00, Denis Nikitin 30.05.2021 05:19:00
#2 Опубликовано: 03.06.2021 12:52:29
Wesly Centerwall
Wesly Centerwall
26 сообщений из 156 понравились пользователям.
It seems like the save function is not saving the combobox list selection.
Tested it a few times and entered values seem to save just fine, but the all combobox selections revert back to the default.
Andrey Ivashov 04.06.2021 04:09:00
#3 Опубликовано: 03.06.2021 12:59:27
Wesly Centerwall
Wesly Centerwall
Also, I've seen some past discussion regarding this export to AutoCAD feature:
Any chance this is now available? I know I have some engineering project where this would be quite nice.
Simple DXF export would be perfect.
#4 Опубликовано: 06.06.2021 17:45:27
philippe dalet
philippe dalet
18 сообщений из 34 понравились пользователям.
Улучшения
Исправления
Разное
  • Refactoring.
Download
hello Andrey,
for debian & ubuntu & mint
smathstudio_0.99.7822_all.deb
https://mega.nz/file/Bh5EzTjb#MUJzYdU7cREZtE7Wv2f-nC3BtO6YicyD1X-FXVjg6uI
created with debreate.
philippe dalet
France
Andrey Ivashov 06.06.2021 21:00:00, Serg 07.06.2021 04:50:00, sergio 07.06.2021 05:18:00
#5 Опубликовано: 27.12.2021 00:09:58
susilo widyatmoko
susilo widyatmoko
3 сообщений из 8 понравились пользователям.
let me know when this feature is available, I will be grateful
