Development Tools plugin
Development Tools plugin - for plugin's developers, debugging purposes - Сообщения
#1 Опубликовано: 03.01.2014 20:42:49
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
menu: Insert > Development Tools
SMath file recovery: fix *.sm files with corrupted/unhandled XML structure (unexpected ending, corrupted color codes, title self-closing tag);
Math ⇒ Terms: converter to see/build C#/VB.NET code from SMath math (plain text);
Math's visual debug: to see Term dependancies and lacks;
Network analyzer: to test your network;
System informations: get the main hardware/software infos;
Plugin's folder: open the current assembly location of installed plugins;
SMath Studio 0.96.5146 or later required
#2 Опубликовано: 12.02.2014 18:30:27
UPDATED
- Fixed bug that causes crashes pasting text data on the canvas.
#3 Опубликовано: 13.06.2015 06:59:46
PLUGIN UPDATED SMath Studio 0.97.5581
New tool: "SMath file recovery";
- creates a new file *_RECOVER.sm from your file (if the file is broken and there is some data to restore);
- Just for files broken with "unexpected ending" error message;
- Just *.sm files (can't recover compressed worksheets *.smz);
P.S. made "Backup & Autosave" request in BTS
ioan92 13.06.2015 07:17:00
#4 Опубликовано: 20.07.2015 11:06:01
PLUGN UPDATED
- File recovery: check & fix corrupted color codes (SS-1247)
#5 Опубликовано: 30.09.2015 10:05:52
PLUGIN UPDATED SMath Studio 0.97.5737
- Fixed: error message after using any tool;
sergio 30.09.2015 10:16:00, NDTM Amarasekera 30.09.2015 22:48:00
#6 Опубликовано: 15.01.2017 19:07:28
When calling Insert> Development tools> system information
SMath crashes (with option to recover). I'd like to add system information here ;-)
0.98.6179 Win7
Показать спойлер
#7 Опубликовано: 15.01.2017 20:24:10
Updated, please try if the fix works for you (source is the OS "friendly name", seems the method I've used to get it is WMI/UAC dependant).
Martin Kraska 16.01.2017 12:01:00, NDTM Amarasekera 16.01.2017 12:16:00
#8 Опубликовано: 16.01.2017 12:00:19
Works, thank you.
SMath Studio: SMath Studio Desktop 0.98.6179.21440, portable, x86
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional , x64)
Screen: 1360x768 px, 96x96 dpi
Localization: separator=; decimal symbol=; system decimal symbol=; language=GER
Frameworks: CLR 2.0.50727.5485
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
Davide Carpi 16.01.2017 12:34:00
#9 Опубликовано: 10.06.2017 06:16:38
Mary11
Mary11
Is that an updated version?
Have an awesome day!
#10 Опубликовано: 10.06.2017 07:14:01
Hello [userlink]MaryVR[/userlink],
you can find the most recent version of any plug-in for your own version of SMath Studio in the Extensions Manager (from inside the program, click to Tools > Plugins... then switch Local Storage to Online Gallery; if the background of a plugin is bluish, it means that the plugin is already installed in your program and an update is available)
#11 Опубликовано: 04.02.2019 05:43:52
Development tools crash on requesting system information in build 6970
Показать спойлер
#12 Опубликовано: 04.02.2019 06:15:52
Fixed, thank you
#13 Опубликовано: 04.07.2020 17:22:49
PLUGIN UPDATED SMath Studio 0.99.7251 and later
frapuano 05.07.2020 03:19:00
