Parsing Name Error
Parsing Name Error - Сообщения
#1 Опубликовано: 28.10.2015 16:47:00
Ryan Freund
Ryan Freund
Can someone help fix the error in this SMath file and possibly help me understand where the error is coming from.
Here is the error:
http://1drv.ms/1NBneog
These images never work for me (see below). I'm trying to share them from onedrive. Is there a way to do this?
Error
Thanks!
Gravity - Walls - Exterior - 2x6 Option.sm (700 КиБ) скачан 1255 раз(а).
#2 Опубликовано: 28.10.2015 17:57:11
Ryan Freund
Ryan Freund
Цитата
It seems you are adept of all in one. This strategy, IMHO, gives huges file and the risk of braking something.
Yes you are correct. I just can't stand the thought of having to open and print 100 .sm files. However, I am realizing that there needs to be a balance. I can't do all in one. Although as .sm gets "stronger" there should be less chance of braking. Although the probability of me making mistakes still remains high I suppose.
If there was a batch print than I could see connecting the files. I like using the "include" to connecte the files but maybe if I get better with data files, I could try this. Do you have an example that you could share?
Thank you
