definite integrals
definite integrals - Сообщения
#1 Опубликовано: 08.04.2012 23:04:57
brandog
brandog
any more progress on definite integrals (symbolic answers to things like int(x^2,x). similar to something like a ti89 can do.. I read a post from 2009 saying you guys were working on it. I have tried in the newest version unsuccessfully but I could be doing something wrong.. If so please let me know because if that is the case I can see some huge advantages to using this for my homework assignments! keep up the great work!
thanks,
Brandon
#2 Опубликовано: 12.04.2012 09:19:36
brandog
brandog
up..
#3 Опубликовано: 12.04.2012 10:17:12
Hello Brandon,
There were lots of post on this and similar subjects. See this post http://en.smath.info/forum/default.aspx?g=posts&m=3379#post3379 or this one http://en.smath.info/forum/default.aspx?g=posts&t=1025 for instance, please.
As far as I understood, symbolical integration and some other things specific for CAS system will be available in SMath only when someone is willing to make a plugin, or to improve the SMath's own symbolic engine. I think that nobody can answer, at the moment, when that could be expected.
#4 Опубликовано: 12.04.2012 12:32:39
Radovan, you're absolutely right.
