The problem with the function of the vector
The problem with the function of the vector - Сообщения
#1 Опубликовано: 07.04.2020 11:49:26
Andrey007
Andrey007
Please help with the prZadanie 2.sm (9,86 КиБ) скачан 1365 раз(а).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#2 Опубликовано: 07.04.2020 16:16:24
Andrey007
Andrey007
Файл не найден.
Please help with the prФайл не найден.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#3 Опубликовано: 07.04.2020 16:19:22
Andrey007
Andrey007
#4 Опубликовано: 07.04.2020 19:47:33
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12,66 КиБ) скачан 1356 раз(а).
#5 Опубликовано: 08.04.2020 09:29:23
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15,05 КиБ) скачан 1160 раз(а).
#6 Опубликовано: 08.04.2020 17:48:42
Andrey007
Andrey007
Thanks for the help, be healthy!
