Update dialog is Grey out (disabled) but the dialog indicates there are updates. Bug?
Update dialog is Grey out (disabled) but the dialog indicates there are updates. Bug? - Possible but in update dialog - CUrrent version is not flagged correctly? - Сообщения
#1 Опубликовано: 27.12.2018 18:39:17
dcomer
dcomer
Just downloaded, installed, and ran smath. I decided to check for updates. The dialog indicates there are new updates, yet the Update button is disabled. The build matches in the update and the about dialog, so, I am assuming there is a bug in that the dialog should indicate there are no updates.
#2 Опубликовано: 28.12.2018 06:46:06
1 434 сообщений из 2 912 понравились пользователям.
what version are you running? I cannot reproduce, can you attach a screenshot?
#3 Опубликовано: 28.12.2018 10:28:53
Ruben Sidranski
Ruben Sidranski
Not sure what version of Windows you may be using; however, try running it with admin privileges. I've had a similar issue with updating the main program at work, but not the plugins, and this took care of the problem
