vectorise() go to deep without first calculating the matrix product
vectorise() go to deep without first calculating the matrix product - I think it should multiply the matrices first and then apply the comparison per line. - Сообщения
#1 Опубликовано: 16.08.2019 12:18:08
manti7
manti7
I think the vectorize() command goes too deep in the example. Probably it takes the first row from the first matrix, then it probably tries to multiply it with the second vector. Then I get the error message: Number of rows and/or columns of matrices or vectors do not match.
Can somebody take a look at this, please?
matrix_nested_function.sm (11,57 КиБ) скачан 1007 раз(а).
#2 Опубликовано: 16.08.2019 14:05:19
CBG
CBG
Maybe this is a simple way to solve the problem
matrix_nested_function_CBG.sm (11,45 КиБ) скачан 987 раз(а).
Carlos
#3 Опубликовано: 16.08.2019 14:07:39
Arie
Arie
Can eval input to f() as such
matrix_nested_function_alyles.sm (12 КиБ) скачан 1019 раз(а).
#4 Опубликовано: 16.08.2019 14:50:18
manti7
manti7
Thank you both for the quick answer! I didn't know there was an eval() function. I now understand that SMath resolves everything as low as possible and then calculates in one go. The use of eval() in the right place prevents this.
#5 Опубликовано: 16.08.2019 16:51:54
Maybe you complicate matters or not make it simpler from the truth table.
#6 Опубликовано: 16.08.2019 16:55:56
... some stuff Truth table
Utilities Matrix Truth Table [Locate row_col].sm (43,39 КиБ) скачан 865 раз(а).
