trace() function broken
trace() function broken - Сообщения
#1 Опубликовано: 03.07.2012 03:22:52
1 285 сообщений из 2 205 понравились пользователям.
I get the following with build 4559
[MATH lang=eng]trace(mat(1,3,2,4,2,2))=1@#[/MATH]
I need the trace function to fake the also broken norme() function using
[MATH lang=eng]M:mat(1,2,3,4,2,2)@#[/MATH]
[MATH]norm_e(M):sqrt(trace(transpose(M)*M))[/MATH]
Best regards, Martin Kraska
#2 Опубликовано: 03.07.2012 04:18:12
kmihaylovich
kmihaylovich
8 сообщений из 131 понравились пользователям.
Hmm, what results do you expect?
#3 Опубликовано: 03.07.2012 05:00:09
BTW., trace() is reserved function for debugging purpose - trace evaluations through Output window - see trace()
#4 Опубликовано: 03.07.2012 13:58:26
ok, that is just my fault, I expected trace to be the trace of a matrix, i.e. the sum of the diagonal elements. In fact, I have to use tr(), than everything works as expected:
[MATH lang=eng]M=mat(1,2,3,4,2,2)@#[/MATH]
[MATH lang=eng]sqrt(tr(transpose(M)*M))=sqrt(30)@#[/MATH]
Thanks for the hints!
