Beta: SMath Studio 0.99.7202 (20 September 2019)
Beta: SMath Studio 0.99.7202 (20 September 2019) - Сообщения
#1 Опубликовано: 19.09.2019 19:01:52
SMath Studio
Изменения, входящие в версию 0.99.7202
Исправления
  • SS-4603: Index out of bounds issue fixed happened sometimes on displaying calculation results;
  • Back-compatibility improved for worksheets which contains TableRegion with custom options;
  • Work with big and small numbers improved;
  • Dialog for installing required plug-ins implemented for children Regions;
  • Text formatting shortcuts supported for children Regions now.
Скачать
SMathStudioDesktop.0_99_7202.Mono.tar.gz (1,4 МиБ) скачан 2110 раз(а).
SMathStudioDesktop.0_99_7202.Setup.msi (2,27 МиБ) скачан 4323 раз(а).
frapuano 20.09.2019 08:08:00, sergio 20.09.2019 04:58:00, Davide Carpi 20.09.2019 05:51:00, Martin Kraska 20.09.2019 06:30:00, Radovan Omorjan 20.09.2019 04:24:00
#2 Опубликовано: 19.09.2019 19:02:19
Here is an instruction for developers which describes how it is possible to add children Regions into custom Region plug-in:
ChildrenRegions.pdf (187,22 КиБ) скачан 1029 раз(а).
Davide Carpi 20.09.2019 05:51:00, frapuano 20.09.2019 08:07:00
#3 Опубликовано: 20.09.2019 06:47:39
Andrey,
Word wrap in text regions is great!
The new children mechanism seems to provide a lot of options. First of all I think of plot regions with axis limits and expressions being handled much like in Mathcad.
An interesting option is to provide language-specific definitions, as the contents of a text region including all children can be language-specific. In the past I did this in the Maxima-Plugin-Test using the value of math region descriptions. In fact, you can provide localized definitions by putting math regions inside otherwise empty text regions.
Martin
frapuano 20.09.2019 08:06:00
#4 Опубликовано: 20.09.2019 14:29:08
You mean as a new 2D plugin, that will plot crappy traces
as crappy as Mathacd caused by imposed limits, whereas it
won't plot on pixels anymore. Mathcad plots on ½ pica.
and can about never plot 2 plots of equal height/width.
Argument style is debatable. Older SS does not open
most latest versions. Good idea to relax the old wolf
from reading same paper [same Smath document] as the youngest ones.
Smath handles the X, Y directions by pixels,
Mathcad handles in ½ pica.
