Printed documents from viewer don't show values correctly
Printed documents from viewer don't show values correctly - Сообщения
#1 Опубликовано: 12.03.2014 02:53:59
experimentator
experimentator
1 сообщений из 21 понравились пользователям.
In some cases the values in the printed document don't match up with the values of the viewer. See attached images as example.
Learning by doing
#2 Опубликовано: 12.03.2014 16:31:56
Thank you! I will check it.
