How can we make the user defined function work?
How can we make the user defined function work? - How can we make the user defined function work? - Сообщения
#1 Опубликовано: 28.07.2015 17:30:56
shelley
shelley
0 сообщений из 15 понравились пользователям.
Could anyone look at this?
I really want the first type to be used, I don't want to put everything in a line.
Since I have some more calc which involves loop and if condition, I hope I can get the result use one defined function.
Thank you.
#2 Опубликовано: 28.07.2015 23:11:04
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
You have to remember that a function of the variable x has the form f(x)= 2+x, as an example. what is in parenthesis is the variable (or variables) of the function. I attached your example. Defining exapl as d was just an extra step so I omitted it.
userfunction.sm (4,91 КиБ) скачан 1220 раз(а).
#3 Опубликовано: 29.07.2015 18:13:40
shelley
shelley
thank you. I will try this way in my sheet.
